I had a Krampus in large, I’m 6’2″.
The Krampus was fun to ride but something about the riding position meant I could only get along with it on relatively smooth trails, which are in short supply in The Peak. It felt to me to be a bit head down arse up. I should probably have had the XL. Anyway, I sold it.
I now have a 24″ Plus and it’s THE most comfortable bike I have ever ridden, I’ve got 30mm of spacers under a 0 deg rise 90mm stem and carbon H/Loop 710s and I have a Thomson layback post. The riding position is quite upright but I really like it. I’ve got the eccentric BB in the 6 o clock position and have 175mm cranks but I get some pedal strike on rocky steppy climbs and in ruts so I’ll swap it to 9 o clock and see how I get on. I guess the low BB setting explains the bike’s unerring stability, it’s rock solid albeit nimble at the same time. I love how it feels and looks. It wheelies really well – it’s so long it’s impossible to flip 🙂
However I am disappoint at the Dually / Dirt Wizard combo being impossible to setup tubeless with a floor pump. When I get time I’ll try inflating with a tube in and then remove it carefully to leave one tyre bead locked in, before converting to tubeless valve and presto hey! I hope it goes up. I’ve not had any similar problems with setting up Stans rims.tubeless. I know some people advise a strip of tape just inboard of the rim’s inner edge which I assume is to stop the tyre bead sliding into the V of the rim before inflation – I think this is the problem I’m having when trying to setup; I don’t want to have to do this, and I shouldn’t have to either, the rims and tyres are tubeless ready. Maybe I need a compressor. Maybe I need Maxxis tyres. I really do need a tubeless setup as I’m getting pinch flats even with the tyres inflated to what I consider a too-firm setting.
Anyway, get yersen a blue one 🙂
