Well I rode some pretty rocky stuff a few weeks ago in Wales. – granted on the first day – I did pump up my tires about 1 psi more than normal, not for fear of rim strikes, but because I was using a Nate, and I wanted to minimise rolling resistance. However subsequently – I did lower pressure to normal, for comfort!
Rim width – simples, the wider you go, the lower the pressure. 50 mm you won’t get any benefit from a 4.8″ tire though. Jeff runs a 72mm rim, any wider and it’s more about floatation – which doesn’t make much sense in a half fat bike.
Nate/rabbit hole is nice, but it’s not true fat though 😉
