I just had one die so took it apart to clean to try and revive it – they’re v simple so certainly try this.
If you do – note that there is a small rubber ball in the barrel (horizontal tube at the pump base that screws out) that is very easy to lose. So don’t drop it on the workshop floor never to be found again…
You can in principle get spare parts from Topeak foc if anything looks like it’s failing – unfortunately their distributor is manned by chimps so getting the right part sent out is challenging (on my fourth try now).
Mine is still deceased for reasons I don’t quite understand – it’s leaking air through the hose connector at the base, hard to see why this joint is bolloxed on taking it apart the one time.
