I bought this off Atomizer a few months ago, but my citcumstances have change ( new baby) and I cant afford to finish the build,as I need to pay for the little ones bedroom to be decorated/fitted out...
So, this is the add Atomizer had up, and as nothing has changed since I bought it here it is ( apart from loop bars being fitted )
Jones 29er steel diamond frame and fork plus headset, wheels, tires seatpost, stem, brand new Jones alloy loop bars
Merlin built, bought from Jeff Jones in Dec 09.
23” effective top tube
440mm chain stays
Fork by Vicious Cycles – not suspension corrected. 135mm spaced. Can take fat front wheel.
Chris King black headset
Thomson 100 by 10 deg OS stem black
Eccentric bottom bracket (Bushnell) – can run as singlespeed or geared
Thompson 27.2mm layback seatpost 440mm black
Jones H-bars with straigt extensions and shims for OS stem
Aubergine powder coat – lovely colour!
Excellent condition.
Comes with:
Rack mounts on fork and frame
Full Rohloff cable guides if you want to run it that way
Full cable guides for derailleur gears
Crudcatcher mounting bosses on downtube(and Crudcatcher!)
QR seat clamp (DKG)
Fixed seat clamp with built in rack mount
Spare derailleur hangers for single speed or geared.
Ideal for singletrack and bike packing
Also:
Paul WHub 135mm front hub in silver on Salsa Gordo rim with DT Supercomp spokes
Rear wheel – Royce disk hub (Ti axle/freehub) in silver on Salsa Gordo rim with DT Supercomp spokes, complete with Royce grease tool
Panaracer rampage tyres included
£1300 ono collected or can be posted ( need to check cost ) or I can meet possibly . based near Manchester
Will not split.
rockstarracingAThotmailDOTcoDOTuk
