It’s a little story where I bought a Pitch in Nov ’07, started upgrading it blah blah blah ended up with Fox 36 Van R’s, Hope Hoops, Fox DHX 5.0 Air, Double n’ Bash repeat to fade.
It’s a bit “Overbiked” for most things I do and I don’t think it helps that it’s got ST Highroller on the front and a Maxpro on the rear, round the likes of Llandegla etc it drags like a good un, the bike doesn’t weight that much (31-32lbs).
Do I:-
a) MTFU
b) Stick a set of Advatage 2.25″ on there for more rolling-ness (?)
c) Flog the frame and forks and build summit else
d) Swap/Sell the Forks and put some 140mm jobbies back on there (probably combined with option b))
e) Any other ideas on a limited budget i.e. 2nd hand frame stley option
