Viewing 4 posts - 1 through 4 (of 4 total)
  • Javascript animation equation
  • bluebird
    I need to animate a DIV sliding left to right, but I want it to overshoot.
    I have a variable, for the sake of argument X, that increments between 0 and 1 to represent the percentage complete. This is then used to multiply a second variable that holds the total distance that needs to be moved to create the animation.
    I’d like to be able to pass X to a function that returns 0 when passed 0, 1 when passed 1, but at some point (around 0.85) over shoots 1. I hope that makes sense.
    Can any point me in the direction of a suitable equation.
    Thanks.
    whatnobeer
    something like
    function incX(x)
    if(x == 1){
    return 1
    if (x==0){
    return 0
    return (1.29 * x)
    That syntax is probably wrong but its been a while since I’ve done javascript.
    Bez
    Don’t reinvent the wheel. Use JQuery.
    bluebird
    I’ve worked it out now. Can’t use JQuery.
The topic ‘Javascript animation equation’ is closed to new replies.
