• This topic has 23 replies, 13 voices, and was last updated 8 years ago by ernie.
Viewing 24 posts - 1 through 24 (of 24 total)
  • Japanese Knotweed Treatment
  • marcus
    Does anyone know any contractors which can undertake treatment of JKW in the Derbyshire area (specifically Belper). It is in a pretty hard to reach area and growing between tarmac and a wall. Not really doing any major ‘harm’ at the moment, so I’m thinking spaying at the optimum time over a few seasons will be best. Ta
    iolo
    marcus
    iolo – Thats plan B.
    iolo
    Plan A will be a lot cheaper.
    footflaps
    You can’t buy proper concentrate weed killers anymore over the counter, so any roundup you buy from a Garden Centre is so weak weeds just ignore it.
    iolo
    It worked for me over about 3 years of continual spraying.
    singlespeedstu
    You can buy this though. 😉
    http://www.amazon.co.uk/dp/B008EQV3MQ/ref=pe_385721_37986871_TE_item
    iolo
    You don’t want it too strong as it will kill the plant before the weeds get it. If the weeds aren’t dead, it will just keep growing back.
    Edit: I don’t mean weeds. That should say roots. It’s Friday and it’s been a long week.
    lovewookie
    before knowing what the appropriate treatment would be, how much is there? we talking a couple of plants, or a bush?
    footflaps
    Good spot, used a load of Roundup (from Homebase) last WE on the patio – weeds have got a little off colour but basically still going. In the old days you sprayed and the next day there were black stubs and nothing grew back for months if not years.
    Might use that concentrate neet on the bastards….
    singlespeedstu
    I mix mine triple strength.
    Much better than anything they sell at DIY stores.
    marcus
    2 biggish bushes
    iolo
    Cut them, they’re hollow and pour roundup inside each growth.
    Stoner
    I get mine from the farmers merchant. pokey strong glyphosate.
    fortunately never had to use it on JPK.
    Interestingly I noticed that it’s “endemic” around Morzine/Les Gets. No effort made to eradicate it there.
    iolo
    If it’s too strong, it’s no good for knotweed.
    marcus
    Tordon 22k seems to have been the best – think it’s banned now though. Company called twist fix seems to sell some good stuff
    yetidave
    injection is best, not cutting the stems as this stops the active transport.
    StuF
    We had the Musketeers Group come in spray treat the several large clumps on our front – they weren’t cheap – several k (luckily for us paid for by the vendor)
    We had one shoot grow back a couple of years later which we put some of the round up gel on the leaves and it didn’t come back at all this year.
    I’ll just keep an eye on it and stick some roundup on it if it appears again
    [Edit – we’re on the notts/derby border so not too far from you]
    marcus
    Im not going to be able to inject / treat stems as the stuff is growing out of gap with a building 1 side and the parapet of 5m high retaining wall (above a railway line) the other. It’ll be hard enough to gain access to spray it.
    timber
    Glyphosate/Roundup, 40ml/litre dilution rate and apply several times a year. The chemical is systemic, so is taken into the roots rather than the more common burn off the foliage chemicals, so results won’t appear instantly, combined with the plants resilience. We spray odd bits around the tenant farms.
    Boss’s brother does it for developers down Swansea way, he uses some new mega bucks chemical, but it works with far less applications.
    flip
    I’m licensed to spray and inject, apart from Tordon (which is expensive) i use Rosate 36 which when sprayed on foliage when flowering gives good results.
    It may take a couple of applications but its great and cheap, £30 for 5l or £100 for 20l
    mitsumonkey
    If you aren’t going to grow anything else there kill it with white spirit. Just be careful you don’t burn the fence down 😕
    joat
    Foundations were dug out for an electric sub-station near me, before which they killed off a large clump of JKW. All seemed okay for about five years, it has now started to regrow. What does it do in the meantime???
    ernie
    Is the growth in railway land? If it is report to network rail and they will cut and treat. It’s incredibly nasty stuff and very invasive. I understand the process is cut and treat on site, if the cut material needs to be transported off site it is classed as hazardous waste and should be disposed through a lincsed site (check with the environment agency). The EA also have a guidance booklet on jkw. Btw, I work for nr and we hate the stuff. Costs a bloody fortune to get rid of properly and delays projects I work on. Good luck.
The topic ‘Japanese Knotweed Treatment’ is closed to new replies.
