First – a primer
I’m a bit confused about which replaced which.
If you replaced M471B5773DH0-CH9 with some Crucial ones, then you have M471B5773DH0-CH9 for recycling, yes? And the Crucial ones are now in the Mac?
M471B5773DH0-CH9 is 1300MHz with timing 9/9/9/xx [xx as I don’t know the last timing value] It’s either 1.35 or 1.5V.
As usual Apple is making it really hard to actually find the damn specs, but it looks as though you will be able to run that RAM, as the MSI is able to support 1,35 or 1.5v DIMMS. You should try to find the voltage that the sticks want by googling all the identifiers printed.
If you run RAM that needs 1.5 at 1.35 it’s likely you’ll get crashes.
If you run RAM that needs 1.35 at 1.5 it’s likely you’ll break it.
When you are confident, and have installed some RAM:
1) Make a MEMTESTx86+ bootable USB stick and test it on another machine.
2) Wipe the BIOS on the MSI, boot it, perform a “load failsafe defaults”, reboot again, and if boots fine try “load optimised defaults” and reboot again.
3)Check the RAM [and everything else] voltage is set correctly in the BIOS.
4)Set the memory timings by hand for the values you have found and leave the rest on Auto
5)Reboot again, if all looks good and the machine still boots
6)Run MEMTESTx86+ for 8 hours or two passes whichever is longer. If there’s no errors – CONGRATS
