ive been down loads of caves…..around the area….soemtimes the caves are bone dry and some just have a trickle of water so your just getting wet up to your ankles, but if its rained for a few days or raining continous then you are waist deep in water….. you have to b so careful cos some caves you can be in there for 2 hours or more…treacking your way through, then you have to come back out of the cave the way you came sometimes , and other times you can find another way out.. so if you have been in the cave for a good hour you have to keep an eye on the water rising and if is constantly rising …get yerselves out of there quickly.. limestone is very pouress..duno if i spelt that correctly. caves flood very quickly and up to roof height …. they even shut Ingleton show cave when its constant bad weather …they have a flood line which most of us have seen… now this is a showcave where it is very well lit…… when you enter a cave or pothole you require helmets and lights cos inside these caves its pitch black once you are in …… ive been in caves where normally there is a small waterfall and at times like this in bad rain the small waterfall is ahuge gushing torrent of water running extremely fast…the water is so powerfull….
