With regards to CFM and flow rate, remember that the figures quoted by compressor manufacturers are displacement. This is a theoretical figure based on the volume of air in the piston(s) chamber.
In reality not all of it is compressable and you will only get around 3CFM per horsepower from any piston compressor. (4CFM per HP for vane and screw compressorrs, but they are a different beast altogether)This is called FAD or ‘Free Air Delivered’
Combined with the fact that most air tools state air usage in a low duty cycle means you have to be careful choosing tools to work from hobby / diy compressors.
Anything that has an air motor in and uses air to spin a rotor with blades (ie drill / wrench / screwdriver, sander etc) will use a lot of air as it is essentially just blowing in and out of the tool.
Anything with a hammer type action (ie nail gun) isn’t as bad as the air isn’t evacuated as fast.
Finally, all direct drive compressors are generally a fair bit noisier and less reliable than there belt drive brothers (between motor and air pump unit)
