Viewing 40 posts - 1 through 40 (of 63 total)
  • IT help pretty please; suddenly slow laptop?
  • v8ninety
    Hi folks, wondering if I could pick your brains. I’m no IT expert, but there’s definitely something up with my laptop. It’s gone from lightning fast to sluggish in about a week. Something is evidently making it work hard because the fan keeps kicking in and I get a momentary flash of the ‘busy’ blue circle on the pointer, every second or so. I’ve tried the task manager, and nothing says its using more than a couple of percent of CPU, but that seems a bit sussed.
    System is an i7 2.4ghz proccessor, with 16gb RAM, running Windows 10 64bit. I’ve got AVG and use spybot S&D, although I’m not sure they are the best options any more, and would welcome some recommendations…
    It’s been really good up until about a week ago. Please, point me in the right direction…
    mattyfez
    I prefer malware bytes to spybot these days.
    Also have you run Ms configuration and nuked any pointless start up services etc?
    Check installed apps and again nuke anything unneeded.
    There’s guides in optimising win 10 online.. If you’ve done a big update recently, it may well have reversed any optimisation you’ve done so far, as they’ve pushed out a few sneaky updates recently.. Do it may well be worth googling an up to date win 10 tweak guide.
    v8ninety
    Really appreciate your input. Could you idiots guide Ms configuration for me? I’m very much in the kids paddling pool of IT savviness. I’ll try malware bytes, and I’ll google win10 optimisation. Cheers.
    This flickering blue circle is driving me nuts!
    cyclistm
    I’ve got the same issue in the same timeframe. Laptop that was running fine has suddenly started slowing down and the fan runs lots.
    I’ve run some clean up software and checked for malware but not solved anything yet.
    chewkw
    Hhmmm … something must be going on with your system but I am not sure what …
    Calling Cougar!
    Calling Cougar!
    v8ninety
    cyclistm – are you getting the blue circle flicker too? About once a second? It’s bloody irritating isn’t it? I bet a w10 ‘update’ has buggered our previously fine computers. Grrrrr
    cyclistm
    Yeah I do. I also think it’s related to an upgrade as I can’t see its doing anything else
    Cougar
    I might be tempted to try a System Restore there.
    Then Malwarebytes as suggested. And get rid of AVG, that could be what’s causing it.
    botk
    if fan is running a lot it suggests a cooling issue rather than software. youre not sat with it on you lap are you?
    v8ninety
    @botk, nope, it’s on the kitchen table same as always. I’d think cooling if it was just the fan, but it’s the flickering busy cursor at rest that makes me think there’s something odd going on.
    @Cougar
    ; happy to bin AVG, it is a lot more pop uppy trying to sell you premium than it used to be. What to replace it with though? I’m malware bytesing as I type.
    v8ninety
    Scan complete; it found 13 ‘potentially unwanted objects’ which I’ve removed, but no difference. System restore it is then…
    v8ninety
    Ah. Apparently system protection is turned off, which means I haven’t got any restore points to go to. Thanks, Microsoft.
    mattyfez
    I gave up on avg a few years back as it got a bit demanding on resources for no apparent reason, with pointless real time scanning and other gumph, now I run nothing, or just standard Ms security, but my browsing habits are pretty safe.. If you have teenagers streaming illegal football matches and porn, that’s a different story!
    Cougar
    Windows Defender will kick in if you remove AVG. Use that.
    Cougar
    Yeah, a gummed up air vent can do that. I had it with mine for months, until after umpteen teardowns I finally found a dust bunny the size of my thumb wedged out of sight in one of the cooling ducts.
    How old is it? Not terribly I’d guess, given the spec?
    molgrips
    Check the resource monitor to see what’s using the CPU
    http://www.howtogeek.com/school/using-windows-admin-tools-like-a-pro/lesson6/all/
    Google for other windows versions.
    seadog99
    Use Regedit to check there are no suspicious entries that are starting up is always my first port of call;
    Tutorial
    Cougar
    With respect, that’s a really bad idea if a) you aren’t sure what you’re doing and b) trying to follow a tutorial written for Windows XP when you’re running Windows 10. By their own admission the OP is “no IT expert”; how does one identify a “suspicious entry”?
    You start randomly tearing out anything you don’t understand from the Registry and you’re going to have a Really Bad Day. And that’s before we get into the realms of things like 64-bit Registry Redirection. Things have changed since 2002.
    v8ninety
    @cougar; it’s about a year and a half old, but with light usage. And whilst I may investigate further, I don’t think it’s cooling duct issues, as previously, it was ridiculously quiet with no fan whatsoever ‘at rest’. Now the fan is on and off constantly, even when it’s supposedly not doing anything. Plus, if it was a cooling issue, I wouldn’t be getting the flickering busy circle would I? Dunno.
    I’ve run the resource monitor as Mol suggested (ta) but nothing is admitting to using the CPU. There is a blue line that says that it’s at 137% maximum frequency, but I don’t actually understand what that means, so I’ll let someone else comment or disregard that.
    Windows defender won’t kick in. It notifies me that it’s turned off, and to click to activate it, so I do and nothing happens. I’ve gone to its control panel thingy and it is greyed out, but in the on position. I’ve restarted the machine several times now.
    v8ninety
    Okay; anyone heard of ‘killernetmanager.exe’? It’s hammering my network connection and I’ve never heard of it. I’m watching my network use in real time without any browsers open and I’m seriously considering the prospect of nuking from orbit. WTF is BFNSservice? And why is it using my data? 😯
    v8ninety
    Apparently both of the above are talking to ‘007guard.com’. I have no idea what this is but I’m thinking that it does not involve Daniel Craig…
    molgrips
    It should be at about 3% or so, low single figures. So yes, something is battering your CPU.
    Those things sound like bloatware or something. You can google for the name of an exe and there are loads of sites that tell you what’s ok and what’s not.
    http://www.file.net/process/bfnservice.exe.html
    The answer regarding 007guard.com is a little more complex. Maybe open a command prompt and type nslookup, then put in 007guard.com and see what it says. It’ll say something like ‘response from 1.2.3.4 is 5.6.7.8’ – post both of them up.
    seadog99
    With respect @cougar the registry keys for checking startup applications is still the same XP/10 nothing has changed since 2002 in that respect. Your reference to win32/win64 application calls is irrelevant to my suggestion.
    Entries can easily be googled, I doubt it will be a long list. Its a quick easy way to see what is starting up on your PC. Spyware/Bloatware/Virii are sometimes hidden and do not show under MSConfig hence the need to check the registry.
    I stand by that link with its caveat that a restore point is made and a backup is made of any deleted keys.
    OP I would say you have definitely been snagged by spyware/bloatware
    Harry_the_Spider
    Mine has been slow with the fan churning like a washing machine for the last week. Then there was a Windows update and now it is OK again.
    Don’t know if the two are connected.
    stumpy01
    You haven’t stuck a large folder on the desktop, have you? (Can you even do that with the Win8/10??
    I stuck a folder on my desktop a while back that contained a memory card dump from one of my cameras, which was getting on for 2Gb.
    It massively slowed down my computer – can’t remember why, although I did Google it at the time, but Windows (this was on Win7) really doesn’t like large items being placed onto the desktop.
    Removed the folder from desktop & instantly solved the problem.
    cranberry
    There have been a lot of boobytrapped adverts around recently, served by big name websites.
    http://www.theregister.co.uk/2016/03/15/massive_us_malvertising_campaign/
    That *could* be a cause of slowdowns. Make sure you give your computers a good anti-malware scan and keep apps like Flash and Silverlight up to date if you need to have them installed.
    Cougar
    That probably implies that you still have some other AV installed. That or an infection which is blocking it.
    Both of these are relating to the Qualcomm network card.
    007guard is a side effect of Spybot’s immunisation. It adds a load of ‘known bad’ sites into your HOSTS file and 007guard is the first alphabetically.
    Neither of those statements are correct I’m afraid.
    Would’ve been much more helpful (and less dangerous) to include that in your first post. (-:
    I admire your confidence but it’s hard to say anything for definite at this point.
    molgrips
    Malware is still a possibility of course. Malware often impersonates legit files. So they rename themselves to one of the normal filenames and do their bad shit. The pages that come up when you Google a process often tell you if there are known attacks affecting that file though .
    cbmotorsport
    I often find it’s simply easier not to question why and just backup your files and reinstall the OS, it’s like a new computer again.
    TurnerGuy
    Yes, it is always good to be in a position that you can re-install the OS without ‘too’ much pain, makes sure your backups are healthy.
    bobgarrod
    I’ve had similar problems recently with win10 updates, leading to 100% disk usage. Googling the problem led me to delete certain apps and settings such as superfetch which has solved the problem (until the next update)
    cbmotorsport
    My laptop ran terribly when I upgraded from windows 8 to Window 10. I had loads of issues, performance for starters, it forgot my user account and I couldn’t log in. It was shocking. i bought a fresh copy of Windows 10 and reinstalled. it’s been great ever since.
    Was your Win 10 an upgrade or a fresh install?
    johnners
    It’s a bit late for you but you can “upgrade” to W10 with a fresh install for free.
    v8ninety
    aaargh. I really wanted to fix this without starting again, up unti last week I was really quite happy with my setup. Bloody computers.
    @cbmotorsport, it was an upgrade from 8, but its been stable and a vast improvement on 8 for months now.
    @cougar, re windows defender, I get the notification that says ‘computer unprotected, click to start windows defender’ which i then do, and nothing happens. This is a bad thing, isn’t it? 🙁
    Cougar
    Have you still got the log from the MBAM scan? Could you post it here / email it to me?
    Is your date / time / timezone set correctly?
    Does Windows Update work?
    cbmotorsport
    I bought it through work so free essentially, I also like to have the disc, call me old fashioned!
    Cougar
    How very 20th Century of you. (-:
    cbmotorsport
    Yes, old skool me.
    v8ninety
    Malwarebytes Anti-Malware
    http://www.malwarebytes.org
    Scan Date: 15/03/2016
    Scan Time: 22:27
    Logfile:
    Administrator: Yes
    Version: 2.2.0.1024
    Malware Database: v2016.03.15.07
    Rootkit Database: v2016.03.12.01
    License: Trial
    Malware Protection: Enabled
    Malicious Website Protection: Enabled
    Self-protection: Disabled
    OS: Windows 10
    CPU: x64
    File System: NTFS
    User: Chris
    Scan Type: Threat Scan
    Result: Completed
    Objects Scanned: 406423
    Time Elapsed: 6 min, 26 sec
    Memory: Enabled
    Startup: Enabled
    Filesystem: Enabled
    Archives: Enabled
    Rootkits: Disabled
    Heuristics: Enabled
    PUP: Enabled
    PUM: Enabled
    Processes: 0
    (No malicious items detected)
    Modules: 0
    Registry Keys: 11
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\INTERFACE\{7041156A-0D2B-4DCD-A8EE-D0608BFCB2D0}, Quarantined, [7a99abddd5c49b9bd36c23a3768c8080],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\TypeLib\{E2343056-CC08-46AC-B898-BFC7ACF4E755}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\INTERFACE\{9B41579A-1996-42F9-8F84-7B7786818CEF}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\WOW6432NODE\CLASSES\INTERFACE\{7041156A-0D2B-4DCD-A8EE-D0608BFCB2D0}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\WOW6432NODE\CLASSES\INTERFACE\{9B41579A-1996-42F9-8F84-7B7786818CEF}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\WOW6432NODE\INTERFACE\{7041156A-0D2B-4DCD-A8EE-D0608BFCB2D0}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\WOW6432NODE\INTERFACE\{9B41579A-1996-42F9-8F84-7B7786818CEF}, Quarantined, [8d86ec9c7e1bd1652f105e6823df2ed2],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\WOW6432NODE\CLASSES\TypeLib\{E2343056-CC08-46AC-B898-BFC7ACF4E755}, Quarantined, [27ec65233960bb7bb78804c23fc32ad6],
    PUP.Optional.MultiPlug, HKLM\SOFTWARE\CLASSES\WOW6432NODE\TypeLib\{E2343056-CC08-46AC-B898-BFC7ACF4E755}, Quarantined, [73a008802970df573d02e5e1e220da26],
    PUM.Optional.DisableChromeUpdates, HKLM\SOFTWARE\POLICIES\GOOGLE\UPDATE, Quarantined, [23f00088e2b7f93dc0d5a3c98e76f30d],
    PUM.Optional.DisableChromeUpdates, HKLM\SOFTWARE\WOW6432NODE\POLICIES\GOOGLE\UPDATE, Quarantined, [4bc8c5c38f0a13233c5972fa43c19070],
    Registry Values: 2
    PUM.Optional.DisableChromeUpdates, HKLM\SOFTWARE\POLICIES\GOOGLE\UPDATE|DisableAutoUpdateChecksCheckboxValue, 1, Quarantined, [23f00088e2b7f93dc0d5a3c98e76f30d]
    PUM.Optional.DisableChromeUpdates, HKLM\SOFTWARE\WOW6432NODE\POLICIES\GOOGLE\UPDATE|DisableAutoUpdateChecksCheckboxValue, 1, Quarantined, [4bc8c5c38f0a13233c5972fa43c19070]
    Registry Data: 0
    Folders: 0
    Files: 0
    Physical Sectors: 0
    (end)
    v8ninety
    (I have no idea what any of that means, and I’m really grateful for all your input)
The topic ‘IT help pretty please; suddenly slow laptop?’ is closed to new replies.
