Viewing 8 posts - 1 through 8 (of 8 total)
  • IS to PM brake adaptor (that works with Marzocchi forks)
  • higgo
    Like this: http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
    to put my IS Hope caliper on a Marzocchi PM fork.
    Except this one says it doesn't fit Marzocchi forks – anyone know one that does work?
    higgo
    Thanks
    I think I may have to see one of those on the flesh. It says red but it looks more fuschia to me.
    mrh86
    That mount from CRC works with a little modification. I used to have some mx pros and used that with my shimano is caliper.
    Cant remember which end it was, but you just have to file a bit off the corner of one if the square bits which bolt to the fork itself. Fits fine then.
    mrh86
    damitamit
    The kcnc one is red (disappointingly) in real life… Got one last week.
    higgo
    Ta – I'm not averse to a bit of home bodgery.
    benz
    The Hope one will work.
    Used one to fit Giant MPH IS disc caliper to some PM MX-Pros on Friday evening.
    Took a wee bit to work out why rotor rubbing.
    Therefore file was needed – did not align properly with the PM mount until a little bit of the corner filed away.
The topic ‘IS to PM brake adaptor (that works with Marzocchi forks)’ is closed to new replies.
