I keep getting letters from the Labour candidate addressing me with my full name which is scary as I think they are watching me like the communist spies …
Are you on the electoral role? If so, of course they’re using your full name. If you’ve signed up for anything like a charity, for example, your name will be on a mailing list, which get sold around interested parties who want to send out mailshots.
Almost impossible to avoid, I would suggest every time you get something like that, junk mail, in other words, cross out your name, write ‘RTS’ on the envelope, and stick it back into a post box. If the address has a 2D barcode on it, don’t obscure it, as that contains data linking your address to the appropriate database, and speeds up the process of being removed from the database. A 2D barcode isn’t the line of short vertical lines directly below the address, it’s a little square made up from lots of tiny black squares to the right of the CBC/Customer Bar Code.
I have to update charity databases as part of my job, and it’s a royal pain when labels cover the barcodes, I have to open the bloody envelope to let the scanner see the barcode.
I’m saying this for anyone sending junkmail back, it just makes life a bit easier for the poor sod who has to sit in front of a computer that’s going ‘beep, beep, beep…’ passing hundreds of envelopes in front of a scanner. 😀
