I'm planning on sending away my Classic Steel Hardtail™ frame for a respray and a bit of brazing work.
As it's generally the bike I use in winter, my plan is to run a full length outer cable to the rear mech. However, the existing cable stops are the slotted type, and I'm told by the guys I'm intending to use that they can't drill these out, so they'll need to lop them off (at £8 per piece) and braze new loop guides on (again, at £8 per shot).
At present, there's a stop on the downtube near the headtube, and one towards the axle end of the chainstay, so there's £32's worth of brazing work already.
My question is, would it be worth getting an additional guide welded on the downtube near the BB? I'm concerned I'd need the outer pulled pretty tight to stop it getting baggy over that length of run. I don't want to ziptie it to the frame near the BB, as that'll look gash.
Any thoughts, anyone?
Just totting up what I could potentially spend on cable stop brazing work in order to run full outers everywhere (mechs and rear brake), and it's looking a bit salty.
