• This topic has 48 replies, 25 voices, and was last updated 9 years ago by chip.
Viewing 9 posts - 41 through 49 (of 49 total)
  • Is this a warranty case?
  • Junkyard
    Jamie I think you owe Beyonce an apology
    Tracker1972
    Surely it is Beyonce who should be apologising?
    Jamie
    I think you’re on to something there, Tracker1972.
    *waits next to the phone*
    Junkyard
    martinhutch
    martinxyz
    ALL THE SINGLE PLY TYRES.. All the single ply tyressss. Uh uh oh.
    Lest
    Pinch flat …
    martinxyz
    I ran 20psi in Hans D’s at Coulags and nipped my bead/sidewall exactly like this. I hardly felt it and it was my own fault for leaving the house with such a low pressure. I normally run about 23 24psi-ish on the climbs over there but I thought I’d go a bit lower to prevent pinging off everything in sight.
    It could happen on the first off-road corner on the first ride. It could also happen a few months down the road. It’s tough luck. Order a new tyre and bin that one.
    Or you could sew it with fishing line and smear Aquasure on both sides before running it tubeless with no leaks. Mine sealed fine with Stans after carefully trimming it at the rim side of the bead. If you’re a skinflint,that is :O)
    chip
    (•_•)
    <) )/ All the single ladies
    (•_•)
    \( (> All the single ladies
    (•_•)
    <) )/ Oh Oh Oh
The topic ‘Is this a warranty case?’ is closed to new replies.
