Morning All,
As per title, is there an infallible way of calculating spoke length?
I have a number of wheel building related projects that I’m looking at, but the most pressing is a rim and spoke replacement (a complete rebuild really) of my Alfine 8 speed rear wheel.
I’m looking to use a Sun Ringle Inferno 27 rim- ERD is 601.
I’m struggling a little to find dimensions for the hub but what I have found is as follows:
OLN 135 mm
Spoke Hole Diameter 2.9 mm
Left Flange Diameter 92.8 mm
Right Flange Diameter 93 mm
Left Flange Offset 30.9 mm
Right Flange Offset 23.6 mm
According to http://www.prowheelbuilder.com I get:
Left spoke length: 288.3
Right spoke length: 289.3
With the same information on the http://www.sapim.be site I get the following:
With 1mm rim thickness,
Spoke length non-gear side: 289
Spoke length gear side: 290
Spoke length non-gear side: 290
Spoke length gear side: 291
So, what length spokes do I need?
Would 290 be OK for both sides?
Do I need to add anything on to take account for nipples?
Help!
Paul
