Viewing 7 posts - 1 through 7 (of 7 total)
  • Is there an easy way to mount an old Garmin on a new 1/4 turn mount ?
  • I’d like to be able to swap easily between an old Garmin 305 and a newer 800.
    Is there any sort of adapter available so I can just use the one mount for both devices ?
    swampi
    Yes, sram do one, think they are about 3 quid or so,wiggle did sell them and may still do, i had one and it worked fine
    swampi
    http://www.wiggle.co.uk/sram-quickview-computer-mount-adaptor/
    out of stock but i think they are on ebay amazon etc
    Thanks Swampi, that’s just what I’m looking for.
    My only doubt is that they describe it as fitting any “SRAM quarter-turn Quickview Mount”.
    It looks the same as a Garmin 1/4 turn mount…
    …so why don’t they say it is compatible ?
    I’ll get one for £5.15 from ebay if someone can confirm it’s definitely the right thing.
    swampi
    Yes they fit fine,i used them, the wings have a little indent in the middle and that matches the garmins to locate the unit centrally,even the bryton fits the sram mount the the proud bit of plastic the locates in that indent damges the brytons a bit as they don’t have the indent and the 2 raised locating pegs are slightly diff, just go for it
    OK thanks, I’ve ordered it.
    The old slide and click mount never seemed as secure as the newer type to me, so I’ll probably glue the adapter to the 305.
    njee20
    Yep, I got one a few weeks ago as Garmin have apparently stopped doing the older mounts, and I was down to one between 3 bikes. Works very well.
The topic ‘Is there an easy way to mount an old Garmin on a new 1/4 turn mount ?’ is closed to new replies.
