Viewing 13 posts - 1 through 13 (of 13 total)
  • Is there an adapter to use a 20mm axle fork with 15mm hub and axle?
  • cjr61
    Or should I find some 15mm lowers?
    Thanks
    nickjb
    You’d need a custom axle I think. Are the hubs definitely not convertible? If not its still probably cheaper to swap hubs
    cjr61
    Assumed the hub wasn’t convertible…might have to double check! Novatec D541SB….
    Thanks
    Fat-boy-fat
    Can sell you a cheap flow ex rim on DT Swiss 350 20 mm hub if you’re interested.
    thejesmonddingo
    These should do it,they’re a push fit.
    Other brands are available
    thejesmonddingo
    I used similar on my Crests,when I changed forks from 20mm to 15mm.
    cynic-al
    Those are specific to the hubs.
    thejesmonddingo
    Sorry,it’s Sunday morning,you’re right al,you may find that that they use an adapter for 15mm as Google says they sell them in 20mm ,15mm and QR.in which case removing the adapter may well do it, as the default is usually 20mm.
    cjr61
    Thanks all. I think I might have found some Novatec adapters (should have checked first).
    Thanks
    thejesmonddingo
    And ali-express sell a 20mm end cap.
    cjr61
    This the one you found thejesmonddingo?
    http://s.aliexpress.com/zyIbYbIR
    cjr61
    Sorted! Thanks all. Novatec EU selling them for £12 delivered. Cheaper than new lowers or new hub.
    Thanks all
The topic ‘Is there an adapter to use a 20mm axle fork with 15mm hub and axle?’ is closed to new replies.
