Thought I’d bent my mech cage and/or hanger. Straightened the hanger, but it looks like the surface that mates with the hanger and the surface that mates with the cage are not coplanar (to use the fancy word).
So the mech body itself must be bent right? They’re not meant to be like that, Shirley?
It seems improbable though, since the body is all solid bits of cast aluminium and there’s no obvious bending.
Parallelogram still operates smoothly. It’s a Deore mech in case it’s relevant.
EDIT: Obviously you’ve no idea if my mech is bent if I don’t post the pictures I took of it:
[url=https://flic.kr/p/SQhQJD]2017-03-10 20.27.21[/url] by Dave W, on Flickr
[url=https://flic.kr/p/SQhR6F]2017-03-10 20.26.58[/url] by Dave W, on Flickr
Yup, jockey wheels are way off parallel with the cassette and shifting is sluggish, sometimes non-existent (particularly up) despite good cable.
In the top pic, the cage is sat on a flat desk but the hanger stud is at an angle. In the bottom pic, the hanger stud is horizontal, but the cage is not vertical.
With judicious use of a fortunately-shaped vee-block, a 6″ vice and a pair of mole-grips (all tools of the precision engineer, I’m sure you’ll agree), I managed to bend it back near enough straight.
[url=https://flic.kr/p/Sj4UdU]2017-03-12 13.00.09[/url] by Dave W, on Flickr
Yes but at least you didn’t find out you’d weakened it to the point of imminent failure halfway up some hill 20miles from home…but I’m sure that won’t happen to the op….probably.
Good skills straightening it without snapping though. I’ve snapped all but one that I have bent back (or tried to) over the years.
Since it’s the steel bit I’m bending rather than the ali, I’m reasonably confident that won’t happen. Still, I’ve always wanted to try singlepseeding 😉
Posted 7 years ago
Viewing 12 posts - 1 through 12 (of 12 total)
The topic ‘Is my mech bent?’ is closed to new replies.
