SO it tries to boot then reboot back to the ‘start’?
You’ve tried the f5 safemode option and it does the same?
So the harddrive is still being recognised but not booting into Windows?
Corrupt copy of windows (if all the above hold true).
Either bang you recovery disc’s in & run em (don’t choose an option to do a clean install, you just need it recovered with wiping the data) or if you have the confidence (or a IT friend) take the drive out, run chkdsk on it (on another machine as a slave drive) and put it back in. This does fix the issue quite a lot of the time, if it doesn’t then there are way to fix it but unless you have some IT experience it maybe difficult and the recovery disc a more sensible option.
OR if you can pop the harddrvie into a another machine, grab your data and then just do a clean re-install, as this is alway the best option.
