• This topic has 17 replies, 13 voices, and was last updated 9 years ago by brant.
Viewing 18 posts - 1 through 18 (of 18 total)
  • Is my bottom bracket shell backwards?
  • thestabiliser
    Just fitting BB to new frame and the Drive side wants to take the anticlockwise cup. This is surely knackers? Checked on Shimano and yep says DS clockwise (73mm BB) shirley the cups will loosen over time? If it was just the wrong cup then shirley it wouldn’t take the thread? Is it time for bike seller HULK SMASH? Or have i got my little head all confusededed?
    aP
    Is it an Italian road bike?
    scotroutes
    What frame? Not an Italian BB shell is it?
    thestabiliser
    Genesis grapil one of the cheapo ones that cropped up on in the psa here
    Dibbs
    Are you working with your bike upside down on the floor? 😳 (I know someone who did that once).
    Wibble89
    Anti-clockwise on drive side and clockwise on non-drive side is correct. It isnt rotational friction that keeps the cups tight, its due to precession linky
    thestabiliser
    Ahhh was looking at 70mm bb instructions. Presumably thats the italian version. Normal service resumed.
    nickjb
    It should be opposite to the pedals if that helps
    seadog101
    Yep, it’s the Wankel effect. It would wind itself loose otherwise.
    samunkim
    Well you learn something new everyday..
    Always wondered why it was counter to what the friction drag would dictate.
    Thanks
    nickjb
    You can test the principal with a pen with a screw on lid. Loosen the lid slightly then hold the pen body and wobble the pen lid in circles with the tip of your finger. It should screw or unscrew the opposite way to the direction of the circles you make.
    reggiegasket
    you can do it with a wine glass too. Swirl the wine round anti-clockwise and the glass itself will try to rotate clockwise. Red wine is better 8)
    cynic-al
    This is where reading instructions gets you…
    IA
    The easy way I always remember it is with drivetrain bits it always* unscrews the direction it would turn if everything seized up.
    *except for some exceptions 😉
    samunkim
    Okay Clever clogsies
    Why isn’t the derailleur jockey wheel counter threaded.
    Guarantee in any MTB event I will always see some poor sod crawling round looking for the shaft and bushes.
    I even carry a spare these days in my puncture kit
    IA
    Really?
    I’ve never seen a jockey wheel come off in use, or seen anyone else with that problem, in a long time* riding bikes.
    *not as long as some, but a good 25yrs+
    andyb39
    Jockey wheels don’t need to be reverse threaded as the applied load is always in the same direction, whereas with a bb or pedal the direction of load on the axle rotates.
    brant
    I was on a ride with Sean Kelly once, and it happened to him. I actually found the bolt in some stones, after lots of other people spent 10mins looking for it. I think people thought I’d hidden it.
The topic ‘Is my bottom bracket shell backwards?’ is closed to new replies.
