Viewing 9 posts - 1 through 9 (of 9 total)
  • Iphone question
  • ashmonkey
    If location services are turned off, can the owner of the phone have it remotely turned back on or track the phone some otherway ?
    I work in a dv unit, someone i work with has been stalked by the bill payer of the phone, i have turned location services off but should i do more ?
    wysiwyg
    Can narrow it down via wifi. But only with ind my iPhone app
    ashmonkey
    Excuse the ignorant questions…
    I’ll remove the fine myiphone app, cheers.
    Not having an iphone i’ve not a clue.
    On the bill, can you see incoming call numbers ?
    If i turn off myiphone app and location services, could the bill payer call apple and have them overwrite these setting to track the phone some otherway ?
    McHamish
    Could the person get a temporary phone rather than using the iPhone?
    warton
    dv unit?
    annebr
    they could try getting their own phone rather than use that one :-\
    pebblebeach
    Domestic violence I assume. Would be better getting another phone if that’s the case.
    CountZero
    As I understand it, turning Location Services off will mean the phone can’t be tracked via iCloud, and I think it needs Find My iPhone installed as well, although I could be wrong on the last bit.
    Of course, it means that apps that require it won’t work.
    ashmonkey
    Thanks for the replies. Its not safe to stop using the phone at the moment, tricky situation.
The topic ‘Iphone question’ is closed to new replies.
