I see someone else tried it since then and says it don’t work.
<nods> I know. The reason I’m so sure it doesn’t work is I’ve tested it extensively myself.
It initially looks like it works, but what I think is actually happening is that it’s getting coarse location data from drive-by MAC addresses it’s seeing as you drive round.
This becomes readily apparent when you’re out in the countryside. The ‘gps’ works quite well in built-up areas but is almost non-existent out in the sticks. That aside though, you only need to compare side-by-side what the iPhone is seeing to what you’re getting on the iPad to see that they’re simply not operating using the same information.
Seems like this would be a fairly easy thing to implement
I’m speculating, but I’d guess that the shortfall is with the phone rather than the tablet. I can’t think offhand of any handset that can act as an external GPS unit (though I’ve not given it a huge amount of thought TBH).
