Viewing 4 posts - 1 through 4 (of 4 total)
  • Intermittent disc brake power problem
  • Handsomedog
    My rear disc (pretty new Deore XT) suffers from intermittent power issues. Most of the time it works fine but occasionally, usually at the worst possible moment, it loses all power and you can pull the lever back to the bar. I assume there’s an air bubble wandering around in there. Anything I can do to settle it or remove it other than a full bleed?
    scotroutes
    Full bleed. I had a similar problem after badly bleeding mine. Since doing it properly they’ve been superb.
    jam-bo
    Full bleed. Old fluid came out jet black on mine. 10x better now, so much so I need to do the front now.
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    Handsomedog
    Cheers folks, I thought as much!
The topic ‘Intermittent disc brake power problem’ is closed to new replies.
