Intense Slopestyle frame. Medium size. £850 posted (UK & Ireland only)
See lots of photos in this Flickr set.
This frame is in very good condition with only a few marks on it. It is a 2009 frame and has recently had all bearings replaced. The lower linkage was also changed to the 2011 upgraded version, which gets rid of the flex that the original version suffered from.
Frame comes fitted with a Cane Creek Double Barrel shock giving 160mm of rear travel. Widely considered the best shocks in the world, this unit is the ultimate upgrade. Shock is fitted with a 400lb spring. Fully adjustable for high and low speed compression as well as high and low speed rebound, this shock can easily be tuned to suit you and your riding style. Click for more details
Also included and fitted is a 2º K9 angled reducer cup which slackens the head angle from 66.5 to 64.5º with a 160mm fork (can also be run with a 180mm fork, single of triple crown). The SS has a 1.5 inch head tube, so with the K9 you use a 1 1/8th steer fork. Cane Creek headset included and all bearings are good. The angle set can be removed easily if you don't want it.More info here.
Seat clamp also included.
