Right, so: just finished the nerve wracking job of cutting down an integrated seatpost. Only to reinsert the ‘seat mast’ (in this case an expander wedge setup that rests on spacers to adjust height in increments) however, there is another carbon tube lower in the post that stops the ‘post’ being inserted completely. Now is this normal? I cant seem to buy another topper – at least find anywhere they’re sold – and even then there is no garuantee they’re going to be shorter.
Now this is a project along time coming and means alot so it’s rather demoralising – any help is much appreciated, thanks!
EDIT: Necessary measurements – Frame seatpost inner – 31.7mm outer – 37mm
current topper length (measured from where it would rest on the frame to bottom of wedge) – 9cm amount still exposed – 2cm
