Never fitted an integrated headset before, its a Cane Creek 40 One of these going into a Dolan Preffisio frame.
I’ve removed the old headset, the new one doesn’t appear to be anywhere near size, I expected the bearings to drop into the frame and maybe require a little tap, the Cane Creek bearings are about 1mm all around, I don’t fancy whacking that into the frame to make it fit!
Bearings are positioned with the angle down going into the frame correct?
I’ve probably missed some change in standards somewhere but I thought you were pretty safe with 1.1/8 integrated?
