Stato, one of the ‘benefits’ is that the design does away with the seat clamp, so if you need to remove the internals, unless you have a spare ready; your bike has no seat post and you can’t use any old seat post as a temporary replacement.
Well yes, that’s kind of the point of it being integrated, to remove the problem of the seat clamp causing binding (apparently, ive not had that issue).
So yes you would need a spare on hand, same issue for your shock, fork, XD freehub and £200 cassette, bearings etc. Its not really an issue if you consider it in the context of a modern enduro bike.
Liteville’s have a 34.9 seat post as standard and I’d be surprised if they’ve changed that. Ah, but how does it clamp without a slot in the top of the seat tube?
Keep up at the back, this is a dropper only frame 😆
