Honourable mention tonight goes to my old Sportful R&D jersey with polartec alpha panels at the front. Soaked through after an hour but still kept me warm. Bit of a go to jersey as it seems to cope well over a pretty wide range of conditions and efforts, dry or wet. See Rapha are doing a new range with similar Polartec Alpha placement, is very good.
Dishonourable mention to my Strada. An hour and a half into the ride, mostly run on the low 15hr setting, it decides to turn itself off. Stop to turn it back on. A couple of minutes later it turns itself off again. Repeat a couple of times, give up, cut the ride short hoping I make it home before the backup joystick dies. Shall be sent back to Exposure as it’s let me down a few times recently 🙁
