So our house has the garage below the ground floor kitchen, which is fine apart from on days like today where it’s bleedy freezing and there’s an artic wind. This means the garage gets really cold (as it has a up-and-over door) but also makes the kitchen floor cold as it is immediately above the garage.
It looks like there’s actually very little between the garage ceiling and the kitchen floor. From the garage the ceiling looks like concrete rafters with a concrete/brick layer, so I’m thinking that adding insulation on the ceiling between the ‘rafters’ should help keep the cold in the garage.
Does this sound sensible? There’s a pipe and a mains cable running between the rafters, but not a lot of plumbing, so it shouldn’t be too inconvenient. Any suggestions for how to cheaply/easily put insulation on the ceiling, instead of under the floor? Plasterboard panels and stuffing the cavity sounds a bit like too much effort to be honest, especially as the fixing points would be concrete.
