I need to insulate the wall under a bay window. I have removed the plasterboard and there is a 75mm airspace then roofing felt and the back of the external render. There are wooden uprights spaced about 30cm apart.
I was thinking of fitting 75mm celotex all round – I know the installation won’t be by the book, but probably as good as I’ll get I figure. Otherwise I can put 50mm board in to get the air gap or add timber to get more depth on the upright timbers.
Do I need an air gap between the external wall and the insulation? It’s an upstairs bay so not sure what’s underneath ATM. Do I need a vapour barrier between plasterboard and insulation? Will I be better off putting rigid rock wool in instead?
