To Uplink and anyone else who is wondering…
The trails are constructed from a deep layer of large sized crushed stone and topped off with thin layer of crushed stone dust. Both layers are heavily compacted with several passes with a whacker plate. The freshly whacked surface is slightly impervious to water. The material underneath starts to dry. As it dries and hardens over a number of weeks, it sucks the top layer down into the cracks between the larger stones. We then top up the dust layer with more stone dust and re-whack. This process is repeated until a solid impervious layer is achieved. It takes a lot of time and effort and depends on the weather a great deal.
If the track is ridden when soft and unconsolidated, your tyres make an impression in the top surface and break the “seal”. If it then rains, water enters through the cracks around the broken edges of your tyre marks. More water in the base material makes it softer for longer and lengthens the bedding in process considerably, making it vulnerable to premature use for a longer period.
So, why are we allowing it to be ridden for Bikefest?
We will be onsite working at Ashton Court for at least a month and a half after Bikefest. After the race, we can easily fix any damage done to the trail quickly to prevent further damage. There is even a chance that riding will actually help the bedding in process, if the consolidation has already reached a particular level. This all depends on weather conditions leading up to the event. Also, such an intense riding period will quickly highlight if we have any issues with the flow in any section of the trail. We can then re jig any bits necessary to ensure they do flow properly in the long run.
Hope this makes sense and persuades a few more riders to keep off the Ashton Court trail (and any other trails being built elsewhere) until they are ready. I’ll qualify all of this by saying that this is not an absolute science and involves a great deal of nuance when applying the rules.
Cheers,
Phil
Architrail
