I’ve got two Inbreds, an old DN6, now the run-around/shopper, and an 853. Both are fitted with Thomson posts and 30mm Salsa boltup seat clamps. The odd thing is that on the DN6 bike with the clamp well tightened there’s a gap of about 3mm between the clamp jaws, on the 853 with the collar at the same torque the jaws of the clamp are almost touching. I’ve swapped the posts and collars around with the same result, so it’s definately the 853 frame.
The post is nice and snug in the 853, so it’s internal dimensions seem right, it’s as if the metal in the seattube is slightly thinner giving smaller outer diameter. Would the walls of an 853 seattube be slightly thinner than a 4130? I’ve ridden the bike well for around 18 months and nothing’s cracked, slipped or misbehaved, so I guess that there’s nothing to worry about (I assume that the clamping force is the same if both are torqued similarly, irrespective of where the jaws are), it just seems odd.
