Viewing 9 posts - 1 through 9 (of 9 total)
  • inbred frame wieghts
  • karnali
    anyone know the weight of a 16 inch geared in bred 100mm model
    cheers
    Eggbox
    about 5lb
    clubber
    Sounds about right. It’s not really the frame for you if you’re worried about weight though…
    cynic-al
    my 1st gen slider was 5lb.
    karnali
    just deciding wether to trade up to a scandal or a ti frame only real advantage is the wieght saving, looking at 1.5lbs is it work the extra cash?
    cynic-al
    up to you – it’s more about the feel of the frame rather than the weight loss.
    USUALLY alu frames are alot stiffer – the Scandal may be a bit more forgiving than that though.
    Ti frames feel different again. Bit odd to be considering frames at £175, £275 and £1K odd though ❓
    PeterPoddy
    IIRC I weighed my slot dropout frame at an ounce or two over 5lb
    I know a Merlin Rock Lobster 853 is virtually a pound lighter….
    karnali
    have an inbred, just got titus motolite to look after for 3 years, had a scandal in the past, just trying ot decide if building a lighter hardtail is worth it, may look out for an 853 rock lobster frame if that is down to about 4 lbs, ti and scandals i think are about 3.5
    ta
    cynic-al
    Does the RL ride in a way you like?
The topic ‘inbred frame wieghts’ is closed to new replies.
