Some thoughts on big gear training for steeper hills:
– Don’t worry about your speed at all when you try it. You might be slower or even faster than usual. Concentrate on your form and cadence instead. And the effort 🙂
– Don’t overdo it – you don’t need to attack every hill in the big ring. Do a few 2-3min efforts like this and build up from there.
– A cadence of 50-70 is a good range to aim for.
– I try and do most of these efforts seated as it helps concentrate on engaging my core when climbing.
– If you start getting knee pain, stop.
Training at high resistance is great way to build strength and form and you’ll find yourself much happier on the steeper gradients. As long as you don’t EXCLUSIVELY climb that way then you’ll find it helps you at higher cadences too.
