Viewing 40 posts - 1 through 40 (of 60 total)
  • Impressive holesaw use of the day.
  • wwaswas
    a hole 50cm deep, 25cm high, 45cm wide
    I bet the surcharge for bit wear at HSS was a bit steep.
    http://londonist.com/2015/04/hatton-garden-raid-first-photos-released.php
    jeff
    Made me think of this
    [video]https://youtu.be/xVywuwMRaCQ[/video]
    allthepies
    They were in there for a very long time, I guess that part of the operation was the reason why.
    Nice thinking out of the box, ignore the massive armoured safe door and just cut through the wall next to it.
    Going to be a bit of a job repairing that. Polyfilla ? 🙂
    lemonysam
    It’s great advertising for Hilti.
    leffeboy
    when i first read reports on this I couldn’t quite understand how big the holes were. Now I understand. That is awesome
    allthepies
    One of these seems to meet the dimensions
    https://www.hilti.co.uk/diamond-coring-and-sawing/diamond-drilling-consumables/430009
    £526.50 a go.
    wwaswas
    *hits ‘request on site demo’ button and says ‘Hatton Garden 22:00’ for location*
    mattbee
    Having drilled 140 40mm cores earlier in the year I wouldn’t want to have been sat behind the rig for those cores!
    bongohoohaa
    I thought the wall was 2m thick?
    tillydog
    They don’t seem to have hit any reinforcement* either. Luck or knowledge?
    *re-enforcement on the met police graphic 🙂
    timbur
    LOL – the shop thought the walls were 2m as well.
    Shoddy builders cuting corners again 😆 Surprised it wasn’ back filled with plaserboard off cuts “for insultaion” guv!
    richmtb
    No rebar?
    Would have thought that was mandatory for a vault
    wwaswas
    It’s an impressive vault door though, even if the walls are made of stacked bags of cement.
    jambourgie
    Was I the only person on the edge of my seat cheering this as if England had just won the World Cup? I know people had there stuff taken, but it’s such a bold/brazen/balls-out non-conformist thing to do in such a bland as bran flakes era. I found it really exciting.
    I fear I’m just a frustrated villain. Would’ve loved to be cracking safes and hiding out on the Costa. However, the idea of going to prison is an effective deterrent for me alas… so I’ll stick to obeying the law.
    marcus
    I want to know how many times they tripped the breaker on the fuse board / transformer
    Klunk
    no style though…. should have left something like this
    househusband
    Three holes, being pedantic.
    Wonder if it was indeed Hilti? Be great advertising whatever brand they used…
    jambourgie
    Does that massive bit just go on the end of your bog-standard drill?
    Unwieldy enough for ya?
    ampthill
    That looks more plausible than the 2 metre thickness first reported
    It wouldn’t have taken muc h to add things that would have made it much harder. I’m think lots of lumps of a harder material like granite. Maybe some scrap hardened steel
    I also wonder of a less consolidated area in the middle would have made it harder
    nealglover
    Steel rebar or granite etc wouldn’t even slow down a proper diamond tipped wet core set up.
    tillydog
    Hilti DD350, apparently.
    nealglover
    I have a DD110-D, that would sail through steel rebar without much effort.
    The DD350 looks like it would do the same without even noticing.
    theflatboy
    househusband – Member
    Looks like one hole to me, even if they did take 3 goes to make it!
    singlespeedstu
    It’d have been attached to a suction drilling rig.
    nealglover
    And incorrect 🙂
    It’s one hole.
    (If you dig a grave, for example, with a spade. Is it one hole or is it hundreds of small holes ?)
    househusband
    And incorrect
    It’s one hole.
    (If you dig a grave, for example, with a spade. Is it one hole or is it hundreds of small holes ?) [/quote]
    Aah BUT…
    Point taken but in the context of this thread, the title of which is ‘Impressive holesaw use of the day’, they did actually use the holesaw thrice in order to create this one larger hole, no?
    nealglover
    I’ve highlighted the important word 😉
    Yes it took three passes to make the hole. Just like you would need more than one plunge of a spade to make a big hole.
    househusband
    Perhaps we can we ‘safe’ly, w’hole’ly agree that we’re both being pedantic…
    8)
    Anyways… I’m assuming that they took all the gear away with them afterwards? I’m with jambourgie… something ‘old school’ and nostalgic about good-old bank robbing like this.
    tonyplym
    Reminds me of when we had a visit from the local CID to where I was working at the time . . . . about 20 years ago we bought one of the early Hilti portable diamond coring rigs, and exactly the same rig had been used to break into a post office strong room. However, the villains had accidentally left behind a bit of the drill’s cooling system. Police were gradually working their way around everyone who had bought the same rig to see who’s rig had the same bit missing. Expect they’ll be talking to Hilti again to get their customer list . . .
    seadog101
    Somebody knew that the concrete was not to safe vault standard, methinks 😉
    piedidiformaggio
    By all accounts there was an identical model stolen from a building site a few hundred yards away a few months back.
    andyl
    surely the door would have been easier to cut? Unless the concrete was very poor quality and they knew it? Or some kind of sensors on the door.
    cynic-al
    I wonder if the makers of Heat will get sued?
    ernie_lynch
    They could have just blown the bloody door off.
    revs1972
    I wonderif they got inspiration from watching the film “the Bank Job”
    jonesyboy
    Made me chuckle as the day before I’d been asked to quote on a job for 3 No. 200mm dia holes through a 2m slab. Could do with asking these guys for a quote 😉
    I hope the 2m slab ends up 500mm like that one though
    bluearsedfly
    I’m surprised there wasn’t a lot more rebar and mesh in there, when we’ve removed vaults in the past they are normally riddled with the stuff along with drop bars which do exactly as they say on the tin.
    We have a fleet of DD350/500s and recently trialled the new 350 which comes with an auto feed. Drilling 350 diameter in flint concrete with rebar it was taking under 5 minutes to a depth of 500mm. Basically with the new model you whack the rig on the wall, press start and it does the rest itself.
    Would have been more impressed if they had rocked up with a Brokk 160.
    thestabiliser
    Anyone know what they got away with – apart from 3 impressive paper weights
    ernie_lynch
    I once saw someone turn up at a trail car park with one of those, you can image the smug look on his face when everyone else had DD350/500s.
    cheers_drive
    LOL earnie
The topic ‘Impressive holesaw use of the day.’ is closed to new replies.
