Contact VMWare support, your fix makes no sense in itself since permissions are either correct and the system works or not and it doesn’t. Maybe it helps briefly via the byproduct of it flushing disk cache and freeing up some memory.
I’m not sure whether Wired Usage is expected when using Fusion as I don’t have my mac with me, but basically it is non-pageable memory, e.g. kernel memory structures which must not be swapped to disk.
Have you done any system or vmware updates recently?
Make sure you have All Processes not My Processes or Windowed selected when you use the Activity Monitor.
NVRam can cause issues like this.
How?
Nothing personal, but whenever any Mac problem is posted, the first two answers are always zap your PRAM and reset permissions. The modern equivalent of ’rebuilding your desktop’. 😆
