• This topic has 30 replies, 23 voices, and was last updated 11 years ago by RegP.
Viewing 31 posts - 1 through 31 (of 31 total)
  • Ignorant question about electrical wiring :-(
  • DrJ
    I just bought a new flat and discovered that the previous owner took every damned thing, including the light sockets, so there are 4 bare wires poking out of the ceiling.
    There is green/yellow, blue, brown, black. Am I correct in thinking that green/yellow is earth, blue neutral, and black and brown live?
    So therefore I can connect my new light fitting to blue+black?
    Thanks for helping me avoid frying myself 🙂
    (why 2 live wires? When would I use that? )
    the-muffin-man
    Isn’t it it illegal to do that (take the fittings, and leave bare wires). I thought you had to leave a basic working light fitting?
    ormondroyd
    My gawd, who the hell would take a light fitting?
    druidh
    If you don’t know what you’re doing, get in a sparky.
    Tiboy
    Typically blue and black would be neutral, the brown would be live and green/yellow the earth
    not sure why you’d have two neutral wires though, are you sure there’s not a red wire up there somewhere too?
    Tiboy
    +1 to druidh, not worth the risk
    wwaswas
    are there two switches for the light?
    jota180
    They were impressively thorough in taking every damn’ thing. They did leave the toilet roll holder, though – I guess their truck was full.
    unklehomered
    as druidh says…
    But what a massize twonk. Did he leave you floor boards and glass in the windows?
    jota180
    I’m sure your solicitor covered off what was to be taken/left?
    Get a spark in [unless you can figure the switching out] and get the last owners billed for it
    Craggyjim
    Sounds illegal to me. Talk to your solicitor. I should imagine you can get the costs of an electrician paid back to you.
    druidh
    And don’t assume that the wiring is correctly colour-matched.
    jonba
    Convinced that is illegal (as we had a similar issue). They need to leave workng and safe electrics. Talk to your solicitor.
    If you google you will find the answer. It is something similar to what jota put up. There is a much simpler version if only one light is controlled off the switch.
    If you are not sure then get a sparky in as you don’t want to be getting it wrong. Death/fire are possible if you mck it up.
    petrieboy
    Get an emergency sparky in to make safe and reinstate fittings, then send the bill to the vendor.
    takisawa2
    Sounds like it could be two way switched. Get a circuit tester or volt.meter on it
    dashed
    Defo should have been covered on the inventory – I’m sure there’s a section which clearly states what is happening to light fittings etc. Have a word with your brief 🙂
    mk1fan
    druidh – Member
    +millions.
    There could easily be a mix of the old and new colour combos, add in multi-way circuits and complete lack of knowledge and you’re likely to have an accident.
    Where are you in the country. I can give the number of a couple of reliable sparks if it’s London / South London.
    Secondly, get your solicitor’s view on the state the flat was presented to you.
    Thanks for the advice, as usual, guys. I am contacting my solicitor now…
    johndoh
    I assume the guy fitted a light fitting and did away with the backing plate at the time and just took the whole thing down again, assuming that because it was his light, he could.
    johndoh – yes I think that’s what he did. He bought a fancy light fitting, and took it with him, which is fair enough, but he didn’t leave me anything I can even put a light bulb into.
    Taff
    Was it in the sales agreement for them to take the fittings?!
    Also if there were bare wires then that’s a major issue!
    Murray
    DrJ – the contract normally specifies that fixtures and fittings are part of the sale – that covers light fittings, switches, taps etc. If he wanted to keep hold of his fancy light he should have got it excluded from the contract. In any case he has to leave the premises in a safe condition i.e. no bare wires.
    You’re being too nice – good karma.
    bigblackshed
    Jota180’s picture is correct for a single way circuit. IE: 1 switch 1 light.
    If you’re not sure what you are doing get a sparky or at least someone who does know.
    Also call your solicitor ASAP. Ceiling roses, (as in the picture) are classified as fixtures and fittings, and are not to be removed by the seller. The dangling light fitting (pendant) is also, unless it was a decorative light, then it may be removable if it was stated as such in the sale agreement.
    stevie750
    Is it a repossession, then nothing you can do. Repo’s do tend to have all fixtures, fitting, plumbing etc removed by the previuos owner.
    If it’s not a repo then get a spark and contact solicitor
    stevie750
    oops
    49er_Jerry
    In Sheffield? If so, I an pop round and put a standard rose on for you.
    Eco Electrics. Contact details on my website.
    konagirl
    stevie750, it is still an offence to leave bare wires, even if its a repossession. There should be a ceiling rose / pendant that the new owner can put a bulb into at every light fitting. Similarly there should be at least one working toilet & sink for sanitary reasons. The only exceptions I know of are if the property/land is bought in a derelict condition with full knowledge of it being uninhabitable prior to purchase.
    OP, as has been said, get a spark to sort it and get your solicitor to invoice the seller (including his own fee).
    tinsy
    Just have a go, whats the worst that can happen?
    The fuse should save you.
    johndoh
    Assuming they haven’t taken those too…
    RegP
    My gawd, who the hell would take a light fitting? [/quote]
    Well the light fittings may have been very expensive. But they should of put a few ££ worth of basic pendent back!
The topic ‘Ignorant question about electrical wiring :-(’ is closed to new replies.
