gonefishin – Member
The answer would involve saying cold weather is better than hot weather or vice versa……So I assume you don’t know the answer??
what the actual composition of the LPG is,
As in? LPG for central heating is standard you would know it?
find out how the off loading systems work (e.g. is there any vapour recovery),
Yes there is according to driver
find out if the tankers are refrigerated or not,
No they are not
plus the fact that you are likely to buy your LPG “when you are about to run out”
Most people try not do that some people get passing deliverys others have a device to inform the supplier refill at a set amount left ie 30%. Others top up when they think have used 400 litre. Not many people are daft enough to leave it to the last moment ie like this winter when you would have ended going without for a week or more. So you don’t really know the answer? By the way the variation is not that small between winter and summer.
