cynicism mode: pros can make any bike look good, that berm looks very groomed for the event, and I expect the dirt he puts his bars into was the fluffiest muffin brown pow possible.
I don’t like these obviously staged shots, with backlighting etc.
He’s probably had to keep riding that same corner what, 10-15 times to get that shot…
It’s not like he’s on his way to work, on the ring road.
Full respect to him.
If I tried that it would be like when a bison goes down on the plains.
A big dust cloud as a desperate lame beast proudly trying to stay upright.
It’s just hypersync where the shutter speed is high to freeze motion and knock the ambient back and still sync the flash above the the normal 160/250th. No HDR as the blacks are 0,0,0 RGB or close to it.
There is a whole bunch of processing going on there. Compare it to the video. Ok it isn’t the usual crazy all-grey HDR, but it is still quite processed looking. And the whole overdone flash thing looks crap for MTB photography IMVHO – it makes that picture look like a studio shot with a totally different background pasted in. Artificial and jarring, but then I guess that is exciting to a certain demographic.
I like it. For me they’ve underexposed the ambient a little too much though.
Definitely not HDR IMO. Would be tricky for an action shot anyway surely? I guess you could put the camera on a tripod and make a HDR background shot then take one with the rider in and add it. Not sure why you’d bother though.
If you have 14 stops of dynamic range to play with from a modern sensor then it’s just a lift of the shadows and a pull down in the highlights (if they are not blown) the flash (camera right) is going to lift the shadows and freeze the action. No Fancy tone mapping, no double exposure.
It could well be a composite image using an HDR background/foreground and a wider aperture, faster shutter action shot with multiple flashes to capture a crisp, bright moving subject…
It looks like there’s a flash hidden out of view highlighting the dust trail behind, but it doesn’t seem to be casting much shadow across the trail or illuminating anything else, and something is illuminating him from high up in front and again not casting much additional shadow, but then there’s quite a bit of foreground shadow, and the sky had been made quite blue and darkened a fair bit too to suggest it’s been shot in the early evening perhaps?
Looking at some of grasses in the foreground there’s a couple of blades that could be the same item in two positions brought in from either exposure, but its hard to tell especially at the picture’s resolution.
In fact from viewing the video its quite clear the natural light on the day was almost nothing like that picture shows it to be…
See Hazy background sky and a high sun casting lots of shadow and the straw like grass has gotten magically greener…
The reason for doing this much processing of an image is simply to make the image more striking and make the subject stand out more from the background, but it does make it seem quite unnatural and serves to make it a bit unclear as to what time of day it was actually taken, humans have quite an instinct for when stuff just doesn’t look quite right, sometimes a light touch is better….
I much prefer image #3 on that PB article a big old blown out corner, Now that looks proper Rad!
Yeah but you can do that simply by underexposing the ambient light. On a bright day you can need pretty powerful flashes to overpower the ambient though.
There’s a flash behind him and another to the right of the shot.
Um, not exactly a photography geek here, but the video capture shows the image in the afternoon sun, the one used in the advert was obviously taken at dusk, hence the bluer sky, shadowed (not greener) foliage, and he’s even taken his front wagon wheel off, because the qr isn’t quite re-tightened on the still/evening shot!
It’s like a really expensive game of spot the difference!
Not necessarily, for the reason’s I outlined above. If you’ve got enough flash power you can make blazing midday sun look pretty dusk-like. It’s a very common trick in action sports photography.
no shit! sherlock. 😯
this:
as grim says it isn’t. a fast flash sync speed drops the ambient (darker sky) and using a hyper sync trigger enables you to do this and you need a slower duration flash and to match the peak output to the exposure window of the high shutter speed, you lose power this way but a more powerful flash deals with that. the high sync speed means you also lose the blurred edges from the long ambient exposure/flash mixing.
in short he knew what he was doing, knew the shot he wanted and used the right equipment in the right way
