Having a couple of issues regarding the setup on my Absolut.
I have been having issues with the singlespeed setup (horizontal dropouts). It seems that whenever I pedal the chain starts to skip with a series of loud clangs and the back wheel comes out of alignment. I have tried it with the chain very tight and it didnt happen as much, loosen the chain and it happened a lot more.
I managed to narrow it down to the disc brake, remove the rotor and the problem stops. Its got a 185mm rotor on the back, and the caliper is mounted with a 185mm adaptor.
I guess that buying a longer chain will solve the problem? Or will I need to buy a smaller adaptor and run a smaller disc?
Secondly, when I took the disc out of the brake I made sure not to squeeze the lever. However the bike slipped (no work stand) slightly and the lever was knocked, causing the pistons to move…and now I cant get them separated.
Easy solution or am I looking at a full bleed to sort it out?
Sorry for all the super idiot questions 😳
