Saw this on the mtbr forum
The CCDB is a great shock when adjusted well for a bike designed to work well with coil shocks.
But not a good match for the SL or SL-R. The SL suspension leverage is very flat to match a rising rate air shock, and the CCDB would have to be over sprung to avoid deep travel wallow and hard bottoming at the sacrifice of good smaller bump and overall handling.
Dave Weagle, the suspension designer of the Mojos, when I asked him, recommended the Fox RC4 for the SL. The RC4 has more rising rate deep travel damping and air spring assist that could be adjusted to match the SL much better. Also the externally adjustable air spring assisted X-fusion coil and Elka 5 shocks might work well, call those companies first to see if they can set up a good tune for the Mojo SL.
