I bought one back in august to replace a 2005 specialized enduro. Its a very good bike, goes up hill a lot better than the enduro, goes downhill slightly better than the enduro. So alround I’m pretty pleased with it. I went for the large frame, whereas on the enduro I was a medium. I’m using a shorter stem on the mojo.
Rear suspension is pretty sensitive to getting the right pressure, the sweet spot seems to be very narrow +/-5psi.
Weighs about 29lb with fox 36’s, reverb seat post, dt ex5.1d rims. XT and SLX kit. Similar build on the enduro was around 32lb.
I’ve had no problems with it, its been crashed, had rocks bounce off the downtube etc, ie ridden and used the same as the old enduro, and no issues so far.
