Pictures are Here!
I have owned this from new and it has been an amazing bike. Climbs like a mountain goat and is smooth like butter on the descents. I had it as quite a rugged build which came in at 28lbs. The frame + shock come in a 6lbs. It has always has the best of care as I have worked in bike shops the whole time of ownership.
Would like £800 for it.
The shock is a 2010 Fox RP23. It has never had the bearings replaced but they have been re-greased twice and are still running smooth.
It has been used so bears some scars hense the low asking price compared to other frames like this. The main marks being around the bottom bracket area where the bike suffered from chain suck due to a bent rear mech. The dark brown mark is the adheasive where the chain suck protector was. I have a new one to supply with the frame. Apart from that it's mainly cable rub and a bit from the tyres inside the swingarm. None of this affecs the performance of the frame in any way!
The frame will come with shock, seatclamp, Hope headset (without top cover) and replacement chainsuck plate.
The seatpost size is 31.6. It has a 1/1.8th internal headset. 135 qr rear end and 68mm bottom bracket.
I can post this to anywhere in the UK via next day courier for an extra charge of £15, deliver within a 10 mile radius or you can collect.
Any questions then give me a shout. I've also got 2 forks for sale on my pinkbike buy/ sell, a 32 140 and a 36 180.
