Just can’t seem to get my front XTR brake working correctly. XTR Dual control lever and XTR caliper (975). It really lacks power and I can even get the wheel to move through with the lever pressed.
Tried different rotors (Alligator rotors), new pads and still pretty much the same. Swapped back to old XT rotors yesterday, sprayed disc brake cleaner on rotors/pads. Then watered down the area with watering can. Suddenly worked fine around the garden. Went back to get bike out the next day and its back to having no power and not grabbing.
Can’t see a leak, but it does seem like the rotors/pads keep getting contaminated. Any ideas as to what the problem is? If the caliper is leaking how do i fix this?
Thanks
Amit
