Two years of trouble free motoring and not a penny spent other than a pre-roadtrip service.
Last week the oil light came on and the best I could do was grab a bottle of cheap stuff from a motor disco and top up, so I did, and promptly forgot about it. Yesterday the light came on again so I went to top up and found the minging yellow grease under the cap. Not a lot, but enough. I checked the coolant and it’s gone very dark and grimey.
I’m not a mechanic but I know enough to suspect a head gasket failure. Currently procrastinating on here rather than get on with an inspection.
Feel free to speculate and throw big numbers and £ signs at me.
[Disclaimer; I don’t have a T5 and I’m not a mechanic, I could be wrong on my estimate ;)]
It might be cheaper than you think, a head gasket isn’t hard to replace is it? I’ve only ever done motorbike head gaskets, and they were far from difficult.
Oh dear, get it looked at as soon as. Tow it to garage if you can. Where you based? Find a good independent. It’s heading towards pricey but you might be lucky.
If a water pump failed could it fail gradually or just go altogether? The van has never overheated. Also, would this explain what looks like oil in the coolant?
Water pump seal did that on mine
they can be a mare to get out need a special tool about £400 for the job at VW van centre Thought that was 5 years ago
There is no timing belt, it’s got a chain. Not sure if it’s ever had a water pump.
I just went out and checked the coolant reservoir. It’s almost entirely oil.
No yellow grease on the dipstick though. Just what I’d describe as a ‘normal’ amount under the cap, like a smear around the threads from condensation or something.
We had an auto Golf that spewed oil onto the cooling system, erupting out of the header tank like expanding foam.
When the oil cooler fails, the oil is at higher pressure than the water so its forced into the cooling system and contaminates the system. It never overheated or damaged the head. It was a pain flushing the rad and heater matrix but it worked fine after a new oil cooler was fitted.
If your expansion tanks full of oil than more than likely its the oil cooler. Pretty straightforward to fix but a bugger to totally flush out of your system.
I’m psyching myself up for it. Is there some kind of magic fluid available that I can use? Trying to think of something that won’t rot any seals or anything.
I took the radiator out and flushed it upside down, back to front any which way using fairy liquid and hot water, then flushing it through with a hose for a while. I disconnected the hoses to the heater matrix and attached longer hoses to try to flush it through in both directions. Take out the thermostat housing toflush out the block too. There may be a block drain plug somewhere too. There is one on my Land Rover. Be systematic.
It’s a job that just takes time. Flushing stuff at garage paying hourly rates makes it well worth doing it yourself.
May not be as bad as you think. As someone has said the oil coolers are prone to failing. The cooler is a heat exchanger where the oil passes heat through a matrix to the coolant. if the matrix is corroded and a pin hole appears it will pass whichever fluid is at the highest pressure into the other. In this case engine oil into coolant.
Get the heat exchanger pressure tested before anyone pulls the cylinder head off your van!
Then as mcmoonter has said really flush the cooling system, best using a flushing agent to help. Then when you have got as much gunk out as possible refill using the proper pink G12 anti freeze / coolant not the blue standard antifreeze.
To check the heat exchanger take it off the van (its an alloy box shaped thing beside the oil filter housing) fully drain it of oil and coolant. Then make some bungs and im thinking a bit of bike inner tube etc held on with hose clips with one end tied up but with the valve accessible . You need to pressurize one side ie oil side. Leave the other side (coolant) open then get some pressure on it around 30psi if you can and stick it in a bucket of water just like checking an inner tube. You will get a load of bubbles as it fills up then look for a steady stream of small bubbles.
good luck!
A friend of mine had the oil pressure warning light come on the other day (2006VW T5 2.5 130bhp 80.000 mile transporter) he kept driving as you do 🙄 took it into the garage the next day to discover Diesel in the sump, catastrophic failure of the lubrication system and a Bill for oil pressure diagnosis, and a new engine, The vans a right off he is gutted.
Remember when I said I wasn’t a mechanic? Well I’m doing a good impression of one!
Two hours work getting that bumper off! At least now I can see all the parts even if I have no idea what they are. Feel free to start naming components for me so I know what I’m looking at.
Firstly, any idea what the bottle of coolant is in the bottom right corner? It’s full of blue fluid and importantly, not oil.
That skinny little intercooler up top is connected to the PAS so that’s not a problem.
I’m assuming that big-ass cooler in front of the radiator is the oil cooler that we (and the blokes on the T5 forum) think is the problem. It’s a lot bigger than I was expecting. There’s also an oil cooler on the oil filter housing. Is there any way I can test the components to see what’s broken before I order anything?
Last question…I was thinking of using Muc-Off to flush it out. It mixes nicely with water and is designed to be kind to components. Any problem with this logic?
I know I’m pushing my luck here and I’m perfectly prepared to drive to a garage and get bailed out if I need to! But who doesn’t like a bit of an educational challenge?
Top tip. whilst teh front is off, get a set of DEPRO caravelle lights fitted and check the T5 forum for the steering column wiring mod. All four lights then will be on when using main beam. Well worth it imho.
I feel your potential pain, just had a quote for a new Clutch and DMF on my T5 130, £1,600 from the stealers and cheapest so far is £830 from Mr Clutch.
Porous head? Hope not but Ive heard of a 1.9tdi Touran suffer from the alu? Head failing.
Classic sign of using the wrong coolant, the VW Specified coolant has anti corrosion inhibitors that are designed around the metals used in the engine,put the wrong stuff in and the first thing that fails is usually the heater matrix, the driver normally complains of a strong smell inside the car.. 🙄
Maybe it’s the angle but I cannot see any sign of orange coolant in what I think is your header tank (round thing with blue lid on passenger side directly above behind end of intercooler).
That’s where the oil has collected. It was full of pink coolant last time I checked.
If it was definitely the oil cooler I’d order one and fit it myself. Is there any way to check where the leak is before I hand it over to the garage with a sack load of money?
Took the undertray off and had a good look around, no sign of anything making it to the outside world.
Best thing to do would be to find the spare part on somewhere like German Swedish and French’s website GSF, or Ebay, then when you know what it looks like it’ll be a lot easier to find.
sharkattack – Member
Let’s not get too carried away now!
Unfortunately you’ve wasted your time pulling the front end apart. The oil cooler (more accurately a heat exchanger really) is between the oil filter and the engine. Remove the filter, undo the water hoses and the centre hollow bolt that the filter screws to. You’ll now have the cooler in your hand. Make sure you replace the seals as well and make sure they seat correctly. Don’t over torque the hollow filter bolt.
Is the oil cooler separate on these or is it a heat exchanger around the oil filter housing?
As far as I am aware they are with the oil filter housing.
Not sure why you have took the bumper off, as you are looking at the intercooler and coolant radiator behind that. Oil cooler radiators on vehicles are tiny in comparison to a coolant item. The laminova type cooler is becoming more popular as it also helps warm the oil at cold engine temperatures then once all up to temperature becomes an oil cooler.
