I have a problem with my rear Saint brake which I will try to summarise briefly.
When I ride the lever pulls to the bar. This leads to many brown pants moments. It takes a couple of pulls to pump up and provide non-spectacular stopping power. This is despite many attempts at bleeding it with all the correct gear.
I currently have the brake off the bike dangling from a spare handlebar.
I have a funnel in the lever, syringe at the caliper and one old brake pad between the pistons.
There is not enough braking power to push out the pistons. No matter how much fluid I put in the pistons will not clamp the pad. If I overfill the system using a syringe at both ends I can clamp the brake pad using the syringe. Even at this point when it should be all locked up there is still loads of pull in the lever.
I just can’t make it solid. The front brake works exactly as you’d expect.
I would have sent it back to Madison but I bought them in 2013, used them for two frustrating weeks in the Alps then threw the bike back in the garage. I suspect two years later they’d tell me to sling my hook. They were bloody expensive as well as I chose to ‘support my LBS’ when I should have bought online.
Yours, Frustrated, trying to fettle a bike for a once every two years trip to proper mountains.
