• This topic is empty.
Viewing 1 post (of 1 total)
  • I guess you can giggle at me…
  • WorldClassAccident
    When changing the hall light switch I was careful enough to turn off the downstairs lights at the fuse box. I was happily disconnecting the wires and fitting the new switch when I got that familiar 240V tingle through my fingers.
    The hall way light switch does the downstairs and upstairs lights which are on separate fuses. D'oh.
    On a separate note, how can a wire suddenly decide to snap? It was in light switch, not under strain and suddenly the switch stops working because the wire has snapped, not worked loose and not a the point it was clamped. Strange it happened at the same time the wife wanted the switches changing…
The topic ‘I guess you can giggle at me…’ is closed to new replies.
