Great cars,had two 130 TDI sports. took them both to 140,000 before I chickened out.
things to check
pollen filter – if it gets clogged then water can seep into the car and get in the convenience module which controls the central locking and air con among other things. – convenience module is in the passenger footwell directly in the path of water from the pollen filter
front wings – if theres any corrosion on the front wheel archs, get it down to a VW dealer. it should still be covered under the VW ant-perforation and while VW haven’t admitted fault they do make a contribution to the repair costs ( i got 70% on a wing that had already had paintwork done)
VCDS – brilliant diagnostic tool that replicates all of the dealer level diagnostics so you can read fault codes and do general fault finding. http://www.ross-tech.com/vcds/download/
VCDS lite is free and is the one you need. you can get a third party interface on ebay for about a tenner and you are away. I’ve got one I don’t need anymore somewhere so if you want it drop me a PM.
