hydraulic brakes seem to be tight ?
please elaborate…
tight as in ‘not much lever movement until they bite’ or tight as in ‘the levers are stiff and move slowly’
former = reset pistons and bleed and see if it goes away (if not see below)
latter = dry/sticky seals, will probably work loose with use but could do with rebuild/service (but not @ £90).
Hayes 9s are not brilliant, but they are very simple, and dead easy to work on. Spares are readily available too, the most common problems are normally degraded seals and calliper corrosion, followed by chipped pistons.
Replacement pistons are ~ £5 and come with a new seal, and you can rebuild callipers yourself at home very easily.
Lever problems are less commonplace but the master cylinder unit (inside the lever body) is a cartridge and is replaceable too for not a lot.
People knock 9’s but they are normally reliable if callipers kept clean and looked after and so cheap and easy to fix they can make great budget brakes long term.
*also – ignore Hayes bleed procedures, overly complicated and doesn’t always work well, best way is reverse fill with a big syringe, never fails and gives a better bleed.
